Faint noise as shift completes...
Old Jun 2, 2019 | 11:00 PM
5280LR3's Avatar
Default Faint noise as shift completes...
I have a faint noise that I can hear just as the transmission completes the shift to the next gear. It sounds like it's coming from the front, possibly right side. I originally thought it might be the driveshaft hanger (center support) bearing. It's not a metallic, hum or grinding noise... more of an "erp" that goes away as soon as the upshift is completed. The only noise that I can compare it to is my Honda snowblower... when you push the auger drive lever the belt engages and makes a little "erp" or chirp noise. maybe I'll have to get the GoPro under there and move it around.
Anyone running a Detroit Axle driveshaft? was thinking about replacing the center support bearing, but for $275 for a complete driveshaft, it's not worth the time or mess.
Old Jun 4, 2019 | 12:08 PM
abran's Avatar
IT sounds like it could be the CV joint at the front end of rear driveshaft, that's a common failure. But also check the front driveshaft CVs, less common but possible.
Old Jun 6, 2019 | 11:44 PM
5280LR3's Avatar
It's got 150K on it and looks like the original driveshaft, so I'm just going to replace it. I saw another thread where you suggested using a GKN driveshaft which isn't that much more than the Detroit Axle one I mentioned. A little more research on the Detroit Axle driveshaft and appears to be hecho en China, so gonna pass on that. Thanks for the advice!
Old Jun 7, 2019 | 01:04 PM
abran's Avatar
Cool. I like the melange of language, "Hecho en China"!
John Galt
Aug 4, 2019 02:13 PM
ATLDisco
Dec 8, 2015 08:08 PM
bmeier
Dec 7, 2014 09:17 AM
AdrenalinPlease
Jun 8, 2013 07:07 AM
NickMcAFP
Aug 21, 2010 05:47 PM
