Fan Clutch. Let me tell you how much I hate you...
Old Nov 18, 2019 | 10:35 PM
Originally Posted by Oceanguy33
I can see that as an advantage...
What did you use to hold the pulley?
The gear wrench pulley holder
Old Nov 18, 2019 | 11:14 PM
Oceanguy33's Avatar
Yes. Checked this - it's righty-loosely this time. Clockwise in other words.
Old Nov 18, 2019 | 11:15 PM
Oceanguy33's Avatar
Just thinking a step ahead here....
the fan clutch/viscous fan is connected to the water pump - or is the pump above and behind more central to the engine?
Old Nov 18, 2019 | 11:18 PM
AF-LR3's Avatar
It’s above and behind. The uppermost pulley on the second serpentine belt is the water pump.
Old Nov 19, 2019 | 01:56 AM
Globetrotter448's Avatar
I have a petrol V6 and it goes anti clockwise to undo - I go by which way the tips of the blade are pointing
Old Nov 19, 2019 | 08:45 AM
Friday Night Disco's Avatar
please elaborate!
I have taken a screw driver and jammed it between the belt and pulley, then used my fan clutch wrench and hammer. This prevented the belt from moving and allowed me to loosen the fan clutch.
Old Nov 19, 2019 | 09:07 AM
Land Over's Avatar
I just had this fun on the weekend. I ended up using the air hammer to hit on the fan clutch nut to loosen the rust, other build up.... Sprayed with penetrant liberally prior to that, of course. Then air hammered the top of the handle of the 36 mil wrench as it was sitting on the nut. Spun right off...
Old Nov 19, 2019 | 06:05 PM
Oceanguy33's Avatar
Funny you say this. I am sure my LR3 V8 4.4 Gas is clockwise. But the tips of my fan point to the left if standing in front of them at the radiator.
Old Nov 19, 2019 | 06:08 PM
Oceanguy33's Avatar
Originally Posted by AF-LR3
I used a 36 inch pipe wrench around the outside of the pulley and giant pair of channel locks to turn the nut. Works the first time every time.
is there room to do that? I assume you remove the belt. I have a 3 ft. pipe wrench, but it looks like there is no room!
Old Nov 19, 2019 | 09:05 PM
KernowDiscovery's Avatar
Surely you meant 'above and beyond'
