Fault Code 2404 - Anybody else with this issue (LR3)
Old Nov 16, 2023 | 12:41 PM
DC DII's Avatar
Default Fault Code 2404 - Anybody else with this issue (LR3)
Just had the code 2404 in the 2008 LR3/Discovery 3.
Looks like Evaporative Emission System Leak Detection Pump ???
Has anyone had to replace or had experience with this fix? Searched here, and looked online elsewhere but there is very little about it for the LR3.
Thanks in advance.
Erik
Old Nov 19, 2023 | 08:16 AM
Rufflyer's Avatar
The pump is part of the evap canister that is above the spare tire on the right side of the frame, there are few quick connect fuel vapor lines and an electrical connector.
Part number for the pump should be WTR500020. You can do a web search for a vender.
Hope this helps
Jeff
File Type: pdf
Old Nov 19, 2023 | 10:44 AM
DC DII's Avatar
Hope this helps
Jeff
Thanks for this -
I also own a 2004 DII and was thinking it may be the fuel cap also. I reset the warning/problem and so far it has not come back. Had very good luck with this LR3 and never thrown codes.
Wasn't sure if a bad seal at the gas cap could cause an "2404" error?
Noted the part and part number and appreciate the response!
Again, thanks-
Erik
Fade89away
Aug 9, 2022 02:48 PM
Rover Hood River
Apr 21, 2022 11:27 AM
ErickLR3
Jan 31, 2022 03:08 PM
weebz
May 2, 2015 10:53 PM
KKN
Jun 23, 2013 12:04 AM
