Fault codes
When an engine, transmission, or suspension fault occurs, does the computer store them so the technician can download them? If so, do these faults record and display the date that the fault occured???
All codes are stored in relitive ECU's and cant be erased without an IDS lap top (test book) some ECU's even keep the codes in a historic file even if the code is cleared. The date is not recorded , but Freeze Frame data stores everything when the fault occured,engine temp,rpm fuel level etc.
mcvayrover
Jan 8, 2024 11:50 AM
kbarker27
Oct 13, 2023 04:03 PM
06Range
May 8, 2013 09:01 PM
