few lr3 questions
Old Jul 25, 2014 | 03:07 PM
TOM R's Avatar
No I did not see it
Old Jul 28, 2014 | 09:39 AM
Nov15's Avatar
We are averaging 18-20 in the city. Getting 22-26 on the highway. Its surprisingly efficient when you drive it right. If you change your driving habits the fuel economy really improves. Driving it "normal" we get the 15 avg. that most people report. I never see less than 18 on highway.
As far as difference in years, not much, but I know that most people will tell you that most of the issues were ironed out by the 2007 model. For sure avoid the V-6. 1 mpg is no reason to sacrifice the power and reliability of the V-8.
After owning it a year now, I can say that nothing feels like a Land Rover. Every car I have driven in since is a disappointment.
Old Jul 29, 2014 | 06:59 PM
TOM R's Avatar
Thanks for the info
Old Aug 22, 2014 | 11:47 AM
TOM R's Avatar
Is there something on this vehicle that would sound like a rod knock without it being a bad engine? Saw one 4 sale says it suddenly developed a knock
For cheap enough may be worth it but I do not want to buy an engine
Old Aug 22, 2014 | 12:03 PM
houm_wa's Avatar
It could be that the seller is describing the sound of a worn control arm bushing as a "knock" not meaning to imply engine-knocking.
Old Aug 22, 2014 | 12:33 PM
cmb6s's Avatar
I haven't heard much about engine knock with the LR3s, but the Disco IIs suffered from a few different ailments that resulted in engine knock. One of these problems that seems to be fairly common is the piston/cylinder sleeves sliding up and down in the cylinder walls and hitting the heads.
Old Aug 22, 2014 | 03:29 PM
jafir's Avatar
Didn't someone post a TSB about the vvt causing a knocking sound?
Old Aug 22, 2014 | 09:42 PM
TOM R's Avatar
What's a vvt?
Old Aug 22, 2014 | 10:19 PM
jafir's Avatar
Variable valve timing.
The LR3 doesn't have an antique boat motor like the older discos
Old Aug 23, 2014 | 11:54 AM
TOM R's Avatar
OK so if it were that then it is fixable? Cheap?
