Flood Damage?
Old Apr 13, 2021 | 02:08 PM
Salvatore Proia's Avatar
Default Flood Damage?
2008 LR3
A Salvage Yard says the ignition key wont come out of the column. Says someone left the sunroof or windows open in the rain. Says there is no other evidence of flood damage. Says everything works in vehicle.
Any thoughts?
How to get the ignition key out. And what else to look for.
Old Apr 14, 2021 | 08:59 AM
EastCoast's Avatar
Ignition key can be a bit fussy coming out at times in my experience. Sometimes it seems like it doesn't want to rotate completely into the disengage position. I just work the key while making sure the steering wheel isn't locked up. Could be the Park sensor is faulty or the linkage is out of sync as well.
Old Apr 16, 2021 | 06:01 AM
Rufflyer's Avatar
May be the key interlock. Disconnect the ground lead on the battery wait a minute, reconnect and then try to remove key do not turn to on position or try to start it, just wiggle to remove it. If the console got wet, the park interlock on the shifter may be affected and not sending proper communications to the rest of the vehicle. This is designed to prevent you from removing the key while it is still in gear.
LR3P0
Jun 1, 2018 05:36 PM
Jadamay
Jan 28, 2017 08:34 AM
fishEH
Sep 7, 2016 11:29 AM
rickatontu
May 9, 2012 09:04 PM
elpapisf
Apr 18, 2012 06:19 PM
