Fluctuating Idle
Old Sep 18, 2011 | 08:26 AM
fanatic516's Avatar
Default Fluctuating Idle
The idle on my '05 LR3 constantly fluctuates at regular intervals between about 500 and 1000 RPM. This ony occurs when in park. When in drive and stopped with the brakes on it maintains constant normal idle range of about 800 RPM.
This fluctuation has caused me to stall out on several occasions when backing out of a parking spot or when maneuvering forward and back to make a multi point turn.
Any suggestions on the probable cause before I bring it in for diagnosis. I don't have a great relationship with my local dealer so I like to have as much information as I can going in.
Thanks,
Jason
Old Sep 18, 2011 | 09:45 AM
Rovin4life's Avatar
clean the throttle plate,
Old Sep 18, 2011 | 09:55 AM
fanatic516's Avatar
Simple as that?
No new sensors or injector cleaning or anything required?
Also, is this something I can let my regular mechanic handle or should the dealer do it?
Old Sep 18, 2011 | 04:07 PM
Rovin4life's Avatar
Injector cleaning is highly recommended on those models due to lean codes from clogged injectors. But if you want to get the service done its easiest at the dealer and ask them they clean the carbon out of the thottlebody. Its apart of the service but make sure its mentioned so they do it. Plus the dealer may want to update any modules that currently need it.
Old Sep 18, 2011 | 05:00 PM
fanatic516's Avatar
Ok thanks for the additional info and feedback. I'll take your advise and make an appointment with the dealer.
Old Sep 24, 2011 | 08:10 PM
dragan's Avatar
Have you resolve your fluctuating problem
Old Sep 26, 2011 | 07:36 AM
fanatic516's Avatar
No, I have not had a chance to bring it in for service yet.
Old Sep 26, 2011 | 11:53 PM
jimbiram's Avatar
If you aren't using Premium fuel, you will be more prone to this happening as well.
Old Sep 28, 2011 | 08:21 AM
thorgal's Avatar
My throttle plate was clean, what was bad was the sensor inside throttle body. unfortunately , one cannot buy it separately. so I had to replace entire throttle body, which runs around $ 300.00.Once I did that , had no problem since, and i only use premium fuel, although i purchased my LR3 used, so no knowledge about previous practices.
prroverguy
Sep 8, 2014 12:40 PM
ndinsmore
Sep 3, 2013 08:11 AM
2000 Disco II
Jul 25, 2011 08:10 PM
roving patrol
Sep 15, 2009 02:08 PM
alemurill
Dec 28, 2008 08:46 PM
