Front Diff question
Old Jan 12, 2013 | 06:59 AM
threalassmikeg's Avatar
It may buy him some time..or it may not depending on the severity of bearing failure.
I would also not waste the time to replace a pinion seal for a leak if the diff is in fact making noise.
If the OP has some sort of obvious binding in his LR3 driveline, there is something wrong that needs to be addressed.
Things I would look for that could cause binding in the driveline
1)Emergency Brake Shoes delaminated and jammed up in the rear brake rotor
2)Brake caliper hanging up, seized caliper piston or sliding pins
3)Wheel bearing catastrophic failure front or rear causing brake rotor to rub on brake components and bind or seize
4)Front or rear differential pinion or carrier bearing failure (catastrophic) causing the pinion or ring gear to be loose, wear excessively and possibly bind/jam up.
Cheers
cornbreadj
Dec 27, 2014 07:50 PM
dusty1
Dec 7, 2014 01:57 PM
mj_duell
Oct 8, 2011 08:22 AM
Disco2Guy
Jun 20, 2008 10:13 PM
Loose_Screws
Jul 22, 2005 12:13 AM
