Front fogs stopped coming on?
I have an 08 LR3 and the front fog lights stopped coming on. The back fogs still turn on when the headlight switch is pulled all the way out but not the front ones. The indicater in the dash for the front fogs does not come on either. Any advice on where to start or what to look for?
Shorted conductor?
If a fuse has blown, you have a shorted conductor in the fog light wiring near one of the two bulbs.
You can usually tape over the damaged insulation just by removing the fog light assembly, (the the question is which one), as the rubbing of the wire is in the few few inches from the bulb.
It is sort of a common LR3 thing however I though by 2008 LR had rerouted the wires a bit near the fog light, but again, they could have got moved in a bulb change.
Trilifter7 (11-24-2016)
link re chaffed wiring
Below is a link on the issue - common and an easy, (for Land Rover), fix.
DISCO3.CO.UK - View topic - front fog lights fuse blown repeatedly
tsuyoi
09-22-2020 10:37 AM
ebg18t
07-11-2012 06:11 AM
wheelgarage
08-06-2009 12:17 PM
cgpilot1id
04-22-2009 11:59 AM
