Front fogs stopped coming on?
Old Nov 22, 2016 | 09:03 PM
Trilifter7's Avatar
8th Gear
Default Front fogs stopped coming on?
I have an 08 LR3 and the front fog lights stopped coming on. The back fogs still turn on when the headlight switch is pulled all the way out but not the front ones. The indicater in the dash for the front fogs does not come on either. Any advice on where to start or what to look for?
Old Nov 23, 2016 | 10:02 AM
DavC's Avatar
check the fuse for that item, sorry don't remember which one it is.
Wiring harness for the fogs is plugged in under the PASS headlamp assembly, but my guess is unless you ripped a wire, or the harness, that isn't the issue. That stuff is fairly robust.
Old Nov 23, 2016 | 08:20 PM
Trilifter7's Avatar
8th Gear
Thanks davC, my first thought was to check the fuses but I haven't looked at them yet. I'll check tomorrow and report back
Old Nov 24, 2016 | 07:01 PM
bbyer's Avatar
Default Shorted conductor?
If a fuse has blown, you have a shorted conductor in the fog light wiring near one of the two bulbs.
You can usually tape over the damaged insulation just by removing the fog light assembly, (the the question is which one), as the rubbing of the wire is in the few few inches from the bulb.
It is sort of a common LR3 thing however I though by 2008 LR had rerouted the wires a bit near the fog light, but again, they could have got moved in a bulb change.
Old Nov 24, 2016 | 10:36 PM
Trilifter7's Avatar
8th Gear
Thanks bbyer! I'll dig into it this weekend and see if I can figure it out.
Old Nov 25, 2016 | 07:47 AM
bbyer's Avatar
Default link re chaffed wiring
Below is a link on the issue - common and an easy, (for Land Rover), fix.
DISCO3.CO.UK - View topic - front fog lights fuse blown repeatedly
Old Nov 25, 2016 | 09:29 PM
Trilifter7's Avatar
8th Gear
Thanks guys! Tore into it tonight and both fog lights had chaffed wires right after the harness. I repaired those and replaced the bad fuse to them and all is well!
tsuyoi
Sep 22, 2020 10:37 AM
ebg18t
Jul 11, 2012 06:11 AM
wheelgarage
Aug 6, 2009 12:17 PM
cgpilot1id
Apr 22, 2009 11:59 AM
KBW
Mar 24, 2009 06:28 PM
