Is it a front hub? 2005 LR3
Old Sep 16, 2020 | 05:35 PM
ljdiscovery's Avatar
Default Is it a front hub? 2005 LR3
We have a 2005 LR3 HSE HD with 148k miles. We recently swapped out the front shocks, the suspension air compressor and just changed out the lower control arms, sway bar links and sway bar bushings. The truck is running and riding great! I am really happy with the ride since swapping out the lower control arms, I had forgotten how well these trucks drive.
While in Idaho 6 weeks ago, I noticed a shutter and drag on the front left wheel while making driving on a mountain road while making a left-hand curve. It was startling. I took it easy on turns the rest of the trip. When I got home we had replaced the lower control arms, sway bar links and sway bar bushings. While making a left-hand turn on a freeway transition I again noticed the shutter/drag on the front left side, in addition, the suspension light on the dash started to flicker on and off. I slowed down a bit and the shutter stopped and the suspension light went out.
No issues were obvious when the lower control arms were changed out.
Thoughts? front hub? It only shows when taking a moderately hard left-hand turn at speed,
Thanks Phil
2005 LR3 HSE HD
148,000 miles
Old Sep 16, 2020 | 05:46 PM
houm_wa's Avatar
....suspension light or 4ETC light? Was it an exclamation point in a triangle?
Old Sep 16, 2020 | 06:52 PM
DakotaTravler's Avatar
^ What he said, cause that kinda make more sense since there are very few temp errors that EAS makes. Meaning that when EAS faults its pretty much a permanent light until restart.
Hubs are pretty easy to check, raise the wheel in question and simply grab it at 12 and 6, rock it. If there is any play, bad hub is very likely but it helps to have someone visually inspect with you when rocking it. It could be an upper ball joint, for example. They don't necessarily make noise when failing, at least not at first. I had one fail BAD. Horrible noise because the seal blew and that capture spring for the seal was rubbing on the rotor. So after I did that one, I decided to just buy another and swap it without inspecting. Sure enough, raised up the wheel and checked it before install it was starting to go but presented no noise. They usually go in pairs.
Old Sep 16, 2020 | 07:28 PM
it is the aft view of the truck with arrow marks on each top corner. It is the one that is on the far left side of the dash in the tach section. It flickered when shuttering and then went away. (stock photo, not my truck)
Old Sep 16, 2020 | 07:29 PM
Odd. Can you pull the codes? If it came on, there will be codes. Just never, ever heard of it flickering before.
Old Sep 16, 2020 | 07:41 PM
I will check it. Gap Tool to the rescue.
Phil
Old Sep 17, 2020 | 11:48 AM
houm_wa's Avatar
Phil, that's indeed the EAS indication....now, as it was brief and in your periphery, and since they are the same color (amber) are you 100% sure that it was that icon and not the 3ETC icon? The description of when it occurred makes perfect sense for it to have been an engagement of the traction control.
Old Sep 17, 2020 | 12:24 PM
it is possible, I thought it was the last one over. I checked the codes this morning and found nothing. Some random codes for mirrors and seats, but they all work fine. Phiil
Old Sep 17, 2020 | 01:27 PM
houm_wa's Avatar
Time to go drive the same roads in slow motion!!!
Old Sep 17, 2020 | 10:14 PM
No codes makes me think houm_wa is correct. If EAS lit up, there would be a code for sure.
