Front hub bearing assembly question
Old Oct 24, 2018 | 07:22 PM
LittleBruiser's Avatar
Originally Posted by jondvd
I have mine completely torn apart if you have a more specific question. I also don't know why you'd be taking the tie rod off unless you're replacing it. For the axle nut I used a Dewalt 1/2" 20v max impact gun. Took a while as it was froze on pretty good cuz of road salt, water and dirt. But if you really want to take the tie rod off, it does have a recessed end for a hex (can't remember the size). Use a box end wrench on the nut and hold the stem of the tie rod with a hex socket. I can post a pic if you need it.
sorry I was exhausted when I submitted the post but I meant the 32mm bolt holding the hub back. Got it done and replaced the rotor and air strut while I was at it with an Arnott strut (lifetime warranty)
DakotaTravler
Feb 8, 2026 03:38 PM
antichrist
Aug 27, 2011 04:31 PM
jrm123180
Mar 17, 2010 10:34 PM
bantham1
Feb 22, 2010 10:46 PM
Rover Chris
Aug 21, 2009 07:39 PM
