Front seats move
Old Mar 26, 2019 | 11:23 PM
schummar's Avatar
3rd Gear
Default Front seats move
So I’ve got an lr3 where the the front driver seat seems to rock when driving. When I accelerate it shifts. Should I replace the rails or any other ideas?
Old Mar 27, 2019 | 12:33 AM
DakotaTravler's Avatar
Hmmm... me too. Its very slight. One of those things I keep forgetting to look at.
Old Mar 27, 2019 | 09:06 AM
Daniel-LR3's Avatar
Same here very slight but to the point of being annoying...
Is the issue the rails? Has anyone looked at the issue?
Old Mar 27, 2019 | 08:34 PM
schummar's Avatar
3rd Gear
That’s what I’ve been told but wanted to see if anyone else has issue and the fix. Are rails pretty easy to install?
Old Mar 27, 2019 | 10:55 PM
Geo's Avatar
Geo
No need to replace anything, it’s an easy fix. I’d forgotten how annoying that was....
There is a cable that inserts into the motor that drives the seat forward and rearward. It’s easy to access from behind the seat. There will be a thick, black, flexible cable with housing that slides out when you pull it towards the driver’s door. With pliers, give the end of square cable several turns (I recall 15 half turns, but you’ll be able to find it on Google if you look). Plug it back in, make sure that it’s all the way in.
What you’re doing is clocking one rail opposite the other to take out the slack.
Free fix and only three minutes at most.....quite rare!
Old Mar 28, 2019 | 08:36 AM
Daniel-LR3's Avatar
You are the Bomb! Thank you so much for the tip, will make sure to do the work and report back.
My high degree of annoyance thanks you!!
Saturnine
Jan 24, 2019 10:06 AM
Womble
Jul 30, 2015 01:58 AM
NhudeST
May 15, 2012 03:41 PM
blackcloud
Appearance & Camping Set Ups
Jan 30, 2011 09:43 AM
dvs_dale
Feb 16, 2010 06:50 AM
