HDC fault … for seconds…
Old Jul 4, 2022 | 10:26 PM
Oceanguy33's Avatar
Default HDC fault … for seconds…
Got an HDC fault special programs off flashed on the info screen. Literally 2 seconds. Then no issues - special programs all selectable. It did this twice.
No faults as per GAP tool.
recently put new (to me) lr4 rear lights in. Didn’t think this was a issue though (with brake lights) …
any other causes of a “momentary” loss of hdc?
Old Jul 4, 2022 | 11:04 PM
houm_wa's Avatar
Check your battery.
What did you do with your LR3 light assemblies? To each their own but I prefer the LR3 look. I have a buddy who needs one. Driver side IIRC.
Old Jul 5, 2022 | 05:01 AM
NJOverland's Avatar
I've had this intermittent and have researched extensively. Basically what I've learned is that it could be anything. People have pointed to the battery and brake light switch. I've replaced both. The brake light switch actually fixed the issue. That is, until I had my front two tires replaced and when I picked it up it came back w/ the lights on. Also, it was originally triggered when getting an oil change. So, I feel like it had something to do w/ a suspension sensor. But anyway, not much help but there's not going to be one answer for you. And yes, people have posted about using non OEM brake light bulbs in the truck for causing it. I have a hard time believing that but I guess anything is possible.
Old Jul 5, 2022 | 06:27 PM
DakotaTravler's Avatar
I second the battery if its on startup briefly with no codes. I had this happened before a couple times, a couple batteries with one being a dying alternator (and battery as a casualty of that). Check battery only after sitting a while so the voltage settles and check running voltage.
Old Jul 5, 2022 | 07:20 PM
loanrangie's Avatar
Did you fit resistors to the D4 lights ? You'll need them on the indicator circuits.
Old Jul 5, 2022 | 10:01 PM
Oceanguy33's Avatar
That's on the to-do list.
Old Jul 5, 2022 | 10:02 PM
Oceanguy33's Avatar
I retightened the negative on the battery terminal. Hopefully that cures it....
toofaroffroad
May 23, 2022 11:56 AM
Jeffrey Changedbygod Ogletree
May 20, 2021 02:06 AM
Frank Swenson
Dec 28, 2019 04:29 PM
cipher982
Nov 9, 2019 11:22 AM
