Hdc fault system??? Please
Old Mar 21, 2009 | 07:09 PM
carlitonsky's Avatar
Exclamation Hdc fault system??? Please
Hi friends, i lost power on my battery and change it for another one (while i get a new one), the thing is as the computer recet ( i think) , when performing system check , a message apear , HDC FAULT SYSTEM .. The thing is , i turn the car off, and turn it againg and the message when out... then couple of minutes laters, got the car on , and message apear.. What can this be? what is this error? couse in the book dosent say much info on this... Thanks
Old Mar 21, 2009 | 10:00 PM
roverguy7's Avatar
you have a fault stored in your t-box ecu for the clutch motor. its because the battery was dead, there is an software update that takes care of this, so if it keeps comming on, you need to go to the dealer. also, check your battery terminals, make sure theyre tight
Old Mar 22, 2009 | 10:55 AM
thank you very much .
Old Mar 22, 2009 | 04:16 PM
what type of battery my car uses? lr3 v8 ??... so i can order a new one..
06Range
May 8, 2013 09:01 PM
mrb06lr3hse
Aug 18, 2012 10:26 AM
