HDC lights on when brake pedal is not engaged
Old Jan 12, 2018 | 09:47 AM
  #21
kosmo0486's Avatar
Have you checked to see if you've had water intrusion? I just had a very similar issue with mine and I ended up finding a lot of my issue were due to deteriorated factory splices. In the meantime since you don't have an IID tool yet i'd check as much as you can without it. I'd focus on the wire splices in the PS floor behind the kick panel and running down into the door sill.
Old Jan 12, 2018 | 12:22 PM
  #22
Mayemaye's Avatar
I'll look into that, tank you!
Old Jan 12, 2018 | 01:42 PM
  #23
houm_wa's Avatar
...no wonder the LR3 has class-leading water fording capability, because if it DOES get into the cabin, you're screwed!
Old Jan 12, 2018 | 02:00 PM
  #24
djkronik57's Avatar
Right? Who's bright idea was it to put critical electrical splices under the door sill?
Is there any easy/cheap way of protecting these lines?
Old Jan 13, 2018 | 07:22 PM
  #25
EastCoast's Avatar
Would silicone caulk work for the wires laying in the floor channel?
binvanna
Oct 30, 2012 12:07 PM
Robover01
Nov 27, 2009 07:15 PM
JavaRacer
ROAMING WITH FRIENDS
15
Oct 1, 2009 06:14 PM
NiteTrain
Oct 5, 2008 07:28 AM
dustondo
Apr 17, 2008 09:28 AM
