Head unit upgrade
Old May 25, 2022 | 07:43 PM
Tyson_wilson's Avatar
6th Gear
Default Head unit upgrade
Hello I am currently trying to upgrade my head unit in my 2006 lr3 se. I have the cubby above my stereo no nav screen. I bought the axxess lr90093 harness but one of the harnesses in my stock stereo has no where to plug into. On top of that, when I reinstalled my stock stereo it has no power at all. Can anybody help me out with this?
Old May 30, 2022 | 02:11 AM
loanrangie's Avatar
Aftermarket harness has no socket for the small auxiliary input plug as i also found out which wasn't an issue since i didn't have the factory aux input. I see you have the fibre optic system ( most) so you need to pickup a separate power input for the head unit, piggy back off one the 12V sockets.
Old May 31, 2022 | 04:26 PM
The_OGCJR's Avatar
I have a pioneer touch screen in place of my oem radio. I used a harness from spiral audiio and it worked great. The only thing is I can't tell time on the display in the guage panel.
I DO plan on installing this pioneer hu in the cubby instead and running it stand alone. Completely separate from the oem radio. I am installing 2 amplifiers. One for the door and one for the subwoofer I am installing too.
Old Jun 1, 2022 | 07:23 PM
loanrangie's Avatar
As soon as you replace the factory head unit you lose the clock on the dash which is n problem since new units will have a clock, only way to keep it is to do as you plan or keep part of the old stereos PCB connected and hidden behind the dash.
Old Jun 1, 2022 | 09:19 PM
6th Gear
Do you know why my stock stereo won't turn on after I hooked it back up?
Old Jun 1, 2022 | 09:24 PM
loanrangie's Avatar
Probably needs a reset, sometimes just a lock and unlock of the car will do it.
Old Jun 1, 2022 | 09:32 PM
6th Gear
I tried that, I tried unhooking the battery for a while, and I tried a hard reset all last weekend. I still don't have any power. I'm stumped
Old Jun 2, 2022 | 02:39 AM
loanrangie's Avatar
Left anything unplugged ?
Old Jun 4, 2022 | 06:33 PM
6th Gear
It's all plugged in, I even pulled it back out and double checked. I think I'm just going to take it to an audio shop. Do you happen to know of ot would be better to take it to a car audio ship or a land rover shop?
Old Jun 4, 2022 | 07:09 PM
loanrangie's Avatar
Definitely not an LR workshop, aren't you replacing it ? Honestly i wouldn't bother putting the original back in.
