Headlight malfunction. code u1a39-87
Old Feb 19, 2019 | 07:07 AM
ljdiscovery's Avatar
Default Headlight malfunction. code u1a39-87
My gap tool showed the following.
Adaptive headlights don’t dance don’t move and are stuck “cross-eyed”. showing “code u1a39-87 communications malfunction of right actuator - bus signal/message failure missing a message.” (Left light points right, right light points left.
I have tried researching solutions. Some say that it is a ground issue. At least one indicated that it was a software issue and that a dealers updates would resolve the problem.
Is there a way to test the ground on the headlight plug? If so. How? Electrical issues are not my strong suit.
By by the way, if you are using your gap tool for diagnostics be sure that you are using a backup power supply, ie a good charger. My battery went flat in about ten minutes while scanning and reading codes.
Thanks. Phil
09dewaed
Dec 4, 2017 06:36 PM
Eurobahn LandRover
Detailing
Jan 18, 2016 04:00 PM
drowssap
Oct 30, 2015 09:25 AM
R anger over
Mar 19, 2013 02:58 PM
tsuami1
Mar 9, 2009 07:33 PM
