heated seat diagnostic help needed
Hey guys I'm having the same issue with my 2005. None of the heated seat work front or rrear. I've checked the fuses in the engine compartment that correspond to the heated seats and both are fine. Could anyone provide a little more detail about how to check the climate control module maybe a picture of it and how to get out it? I appreciate it.
Hey guys I'm having the same issue with my 2005. None of the heated seat work front or rear. I've checked the fuses in the engine compartment that correspond to the heated seats and both are fine. Could anyone provide a little more detail about how to check the climate control module maybe a picture of it and how to get out it? I appreciate it.
The odds are it is not any of the printed circuit boards - they are quite reliable - more like a connector concern or damaged wiring, the normal LR problems.
Upon further inspection, it seems that the passenger seat is working, but weak and the same with rear. Any ideas for checking the resistance on the drivet side?
The other issue is there driverz seat has a bit of a lean to it. Has anyone swapped out thier 05 non lumbar non memory seats for post 2007 seats with lumbar and memory?
Is your engine running when you are operating the seats?
I ask as if the battery is weak and the engine not revved up a bit, that could explain slow operation of the seats.
You might consider just separating the electrical connectors and plugging them back together again? There might be looseness or corrosion to the pins.
I think the solution is something simple as the seats, or at least one seat, is kind of working.
