heated seat diagnostic help needed
Old Dec 25, 2018 | 09:57 PM
bluetick's Avatar
Hey guys I'm having the same issue with my 2005. None of the heated seat work front or rrear. I've checked the fuses in the engine compartment that correspond to the heated seats and both are fine. Could anyone provide a little more detail about how to check the climate control module maybe a picture of it and how to get out it? I appreciate it.
Old Dec 26, 2018 | 12:17 AM
bbyer's Avatar
Default post # 2 above?
Originally Posted by bluetick
Hey guys I'm having the same issue with my 2005. None of the heated seat work front or rear. I've checked the fuses in the engine compartment that correspond to the heated seats and both are fine. Could anyone provide a little more detail about how to check the climate control module maybe a picture of it and how to get out it? I appreciate it.
I assume you read post #2 and went into the referenced files in the gallery and downloaded the relevant pdfs? There is a fair bit of info there. If all quit, the problem is common to all and I think then relatively easy to track down.
The odds are it is not any of the printed circuit boards - they are quite reliable - more like a connector concern or damaged wiring, the normal LR problems.
Old Jan 4, 2019 | 11:47 PM
bluetick's Avatar
Hey there,
Thanks, I did look at post 2 and the PDFs. I've checked the fuses, did a hard reset, and looked under the seats for loose connections. Found nothing. Any suggestions of where to look next?
Thanks
Old Jan 16, 2019 | 10:26 AM
bluetick's Avatar
Upon further inspection, it seems that the passenger seat is working, but weak and the same with rear. Any ideas for checking the resistance on the drivet side?
The other issue is there driverz seat has a bit of a lean to it. Has anyone swapped out thier 05 non lumbar non memory seats for post 2007 seats with lumbar and memory?
Old Jan 16, 2019 | 09:42 PM
bbyer's Avatar
Is your engine running when you are operating the seats?
I ask as if the battery is weak and the engine not revved up a bit, that could explain slow operation of the seats.
You might consider just separating the electrical connectors and plugging them back together again? There might be looseness or corrosion to the pins.
I think the solution is something simple as the seats, or at least one seat, is kind of working.
jackh
Sep 13, 2020 04:39 PM
djkronik57
Jan 8, 2020 07:14 AM
aceeng
Jun 12, 2014 05:51 PM
loomy123
Jan 4, 2014 09:09 PM
donymc1
Oct 22, 2012 06:53 PM
