Heater Core Replacement
Old Mar 15, 2016 | 09:08 AM
abran's Avatar
Originally Posted by delormea397
Not necessarily. They can be clogged like mine is. The drivers side corner of the core is the lowest side so sediment builds up there and is difficult if not impossible to flush or backflush out. Symptoms are poor heat output to drivers side vents. Blend doors and motors are fine.
Touché.Have you tried removing the coolant lines at the firewall and flushing/back flushing there? Seems like that would unclog it.
Old Mar 15, 2016 | 09:09 AM
delormea397's Avatar
Yes, tried that. The tech at the local independent rover shop also tried with his own LR3 that had the same problem. Even went as far as filling the system with CLR solutions etc to try and break it down then using a power flusher to backflush. No luck.
Old Mar 15, 2016 | 09:25 AM
LR3NJ's Avatar
I wonder if hooking up a good strong wet vac would clear out the debris?
I only say that because I have a rental property and the tenant flushed one of those bleach discs down the toilet instead of putting it in the tank. The thing wedged itself in the trap of the toilet.
No amount of plunging or snakeing would dislodge it.
Last resort thought of the wet vac. Put a good seal around the hose and it sucked out the disc.
Old Mar 15, 2016 | 10:14 AM
abran's Avatar
Wow! That's some clog. Good luck
Old Dec 17, 2016 | 08:23 AM
doug88's Avatar
The guy at the shop said they do several a week, it's so common here. They may have just gotten quick at it. We'll see. I don't mean to hijack the thread, just throwing in my 2 cents about what the factory manual says and what my local shop quoted.
Hello I have a 2008 Range rover sport needing a heater core replacement
could you tell me the location, of the shop that said they could do the job for 800.
00
Thank you
Old Dec 17, 2016 | 08:35 AM
doug88's Avatar
Looking for a way to replace my heater core I found this
Would anyone know if this procedure could work on the 2008 LHD Range rover Sport
Heater Core Replacement (Range Rover 4.0/4.6/P48)
Thank you
Old Dec 18, 2016 | 10:13 PM
DavC's Avatar
Sorry to hear of these issues. The one thing I will not tolerate in a land rover is a bad heater core. My POS project white 5 speed D1 has an amazing heater... reverse lights and several other items are another story.
Good luck with the work and bleed it right when you do.
Old Dec 20, 2016 | 05:20 PM
cybercop's Avatar
Just got the bad news of a bad heater core today. Not looking forward to either paying or doing the job. Oh well
Old Dec 20, 2016 | 05:40 PM
houm_wa's Avatar
When the LR3's heater core goes ****, does a bunch of white "smog" enter the cabin like it did in 1989 with my Bronco II?
Old Dec 20, 2016 | 08:20 PM
EastCoast's Avatar
I hope delormea is still active....
I was wondering if when the flush was tried if there was any fluid moving through the core at all? I only ask because I just had mine done and there was no comments about it not pushing fluid through... done with 90 psi shop air. still not getting full heat but still have to investigate the blend door actuator.
