Height Control paddles & steering rattling over rocky terrain
Old Oct 5, 2020 | 05:16 AM
jbullock78's Avatar
Default Height Control paddles & steering rattling over rocky terrain
Hello!
I had 2 questions and looking for some input-
1- Height control paddles are not working I use GAP tool. Do I need to replace the panel on the center console? just an inconvenience vs serious issue.
2- On a light off-roading excursion, there was a lot of rattling in the steering. I have replaced the inner/outer tie-rods recently as well as the control arms 18k ago (1 year). It usually does that, but my co-pilot girlfriend was startled so I figured I'd pose the question in the forums.
Thanks All!-
James
Old Oct 5, 2020 | 02:01 PM
houm_wa's Avatar
I'd need to hear it and/or feel it in order to really take a guess. It could be a lot of things, including nothing.
Old Oct 5, 2020 | 02:26 PM
jbullock78's Avatar
That I what I was thinking re-rattling- No other steering issues etc.
Thanks!
James
Old Oct 5, 2020 | 03:27 PM
DakotaTravler's Avatar
Hs the lower steering shaft been replaced? Do you have it shifted ALL the way up or in/out? I found its best to never adjust them all the way, back off just a hair.
Old Oct 5, 2020 | 04:17 PM
jbullock78's Avatar
No-
the lower steering shaft is original. I don't play with the steering wheel placement very often. It could be that- because it only happens over rocky terrain/trails like something i would describe as a little less than a dirt road
Old Oct 5, 2020 | 06:21 PM
You can certainly try it. It could be the upper shaft bolts. I drive corrugated roads and my wheel certainly does not feel loose. My lower shaft was replaced a couple years ago. Usually they tighten up and cause steering resistance but I know of at least one case where it seems to have gone past that point and them become very sloppy. Probably from forecast steering. Either way its not something I would ignore. With a second set of eyes on the shaft in the engine pay you should be able to narrow it down.
Old Oct 5, 2020 | 09:02 PM
houm_wa's Avatar
I think it's pretty normal to "feel" the terrain through the steering wheel as you drive over it; however, that's different than "rattling." Is this an audible rattle?
Old Oct 6, 2020 | 07:18 PM
loanrangie's Avatar
Could be the roll bar bushes, does it feel loose thru the wheel or is it more the sound ?
Old Oct 7, 2020 | 11:55 AM
jbullock78's Avatar
It feels a bit loose, but only when on washboard/rocky terrain. On pavement- no issues. I will have my local LR mechanic take a look at steering shaft at my 76k service interval.
Thank you!
archaeology_student
Sep 26, 2020 11:07 AM
David Nix
Aug 13, 2018 11:40 AM
Volkov
Sep 27, 2015 06:35 PM
moorebl
Oct 3, 2014 09:59 AM
