HELP! 06' LR3 Won't start, AGAIN!
Old Feb 3, 2016 | 07:46 AM
  #51
AtlantaViking's Avatar
Originally Posted by BruceRover
XROVER - Did replacing your starter solve your problem? I am having the same exact issue in my '06 LR3. Clicking sound for a second, everything comes on, including the F in the Shift position indicator, HDC Fault & Transmission error and no start. The mechanic is replacing the starter engine now.
Did it resolve your starting issues? Thanks!~
I had the same issue with my mine. It was a water issue but not the sunroof, in my case it was the cowl warping. Water would run down the windshield and under the seal. It would then find its was to the Transmission computer on the firewall. To confirm I was getting water I pulled the battery cover, and checked the computer connector (which is on top of the unit - nice engineering there) and found corrosion on the pins. I cleaned it up, and unlike many folks who replace the cowl with a new one only to have it warp again - I taped it off and ran a bead of black silicone to bond the seal to the windshield. I can't say how long this will last but, for me, I haven't had an issue since and its been about 6 months.
Full disclosure, I did a lot of underhood investigations trying to track this down and did throw some parts at it, so it may have been a combination of issues. Here are the other things I did:
1. New starter, just to eliminate it.
2. Removed the ground straps from engine to frame and found standing water in the bottom of the insulation boot. This one really bothered me, simply because it could definitely affect the amount of juice to get to the starter. My solution was to leave it, but also insert an additional ground strap to act as a secondary ground. My own interpretation of this crappy ground is that many owners replace the battery unnecessarily because of the weak grounding issue for the motor. The dealers will happily replace it because its a simple thing and it's such a common topic that everyone points to it at the beginning. Do yourself a favor and clean up the chassis grounds.
This is a serious YMMV issue, as you can see from the older posts - water can cause issues on the interior as well and they are just as real. In my case though it was the crappy cowl as the likely culprit.
Good luck.
Old Feb 3, 2016 | 09:19 AM
  #52
dudeinacabin's Avatar
Default Started replacement
I had the very same problem and it was the starter. After the replacement there were no issues. I also have the '06 LR3
Old Mar 23, 2016 | 01:52 PM
  #53
Originally Posted by horvaro
LR3 does not start
If your battery is in good condition than you need to do the following:
You need to sand and degrease:
1. Battery positive and negative terminal
2. Battery negative terminal to the chassis
3. Power cable connection to the starter
This document can help:
https://landroverforums.com/forum/at...or-removal.pdf
You don’t need to remove the engine undershield or disconnect the ball joint!
This is good info but its missing the one critical step IMO. Just because you have good positive connection from battery to starter, that current has to be able to leave the starter and return to the battery.
The motor is isolated by rubber mounts so there has to be grounding straps to allow that current to return. If you go to the trouble of removing the pass. wheel as noted go ahead and double check those grounding cables from motor to chassis as well - that's where my issue was.
I really believe that the reason new batteries work so often for folks is that they are fresh and able to overcome iffy connections (positive or negative). Eventually, that fresh battery will weaken somewhat over time and you'll be right back to square one. Keep the connections in good condition and I really believe that even marginal batteries will keep these tanks running.
Good info though for sure horvaro.
Old May 29, 2016 | 09:03 AM
  #54
bodyzoo's Avatar
8th Gear
I know this post is few years old but would really appreciate if you could email me the pictures of starter relay cleaning and disassembly.
Thanks,
Old Jun 3, 2016 | 08:14 AM
  #55
Chrisva's Avatar
8th Gear
Hello great info! Where is the grounding strap?
Thanks
Old Nov 26, 2016 | 01:15 AM
  #56
ALLWhiteLR3's Avatar
Default No Start
Intermittent starting issue going on for well over a month now. I changed crank shaft sensor, and fuel pump... still not starting what do i do? what did you guys do? Private mechanic and dealer are perplexed. no clicking sound btw, just crank crank crank, no start... then randomly starts fine...
Old Nov 27, 2016 | 01:17 AM
  #57
EastCoast's Avatar
From what I have gathered on here it could be your battery and/or alternator or even your brake switch. Those are the easier ones to tackle, imo.
Old Jan 11, 2017 | 07:46 PM
  #58
Kelly Ray's Avatar
Default Pics please
Originally Posted by Greg S
Our 2005 LR3 was having the same issue with the starter not working intermittantly. It was driving the wife crazy as the LR3 is her daily driver. This last week it started acting up again. I could get the starter to click but nothing else. After 10 or so tries it would start!
Being a do it yourself kind of guy I removed the starter to check for problems there. Bench testing gave the same results as in the vehicle. The starter gear would push up but no turning of the motor. Further investigation found the internal copper contacts heavily pitted. I removed the contacts and cleaned them up with emery cloth and reassembled. Bench tested perfectly! The LR3 starts better know than ever since we bought it used last year. I have pictures of the starter contacts before and after if anyone is interested in trying this yourself. Its nothing that any shadetree mechanic couldnt do.
Hope this helps.
HI, my LR3 is doing this exact thing! Could you please email the pics to me! Thank you!
azkrayz8@yahoo.com
Old Feb 7, 2017 | 03:45 PM
  #59
Default Still No Start
intermittent starting issue..
new battery
new starter
new egr valve
new fuel pump
new alternator
new crank sensor
cranks and cranks. Sometimes foot on the gas gets it to start... no check engine light... Help!!!
Old Feb 8, 2017 | 08:23 AM
  #60
horvaro's Avatar
Since I fixed it: no issues at all!
My LR3 starts the first time.
