Help with burning smell
Old Mar 3, 2021 | 12:18 PM
Skyjacker03's Avatar
Default Help with burning smell
So the other day I had a plastic burning smell coming for my 2008 Land Rover LR3 (75,000 miles). I took it to a local garage. He had it 2 weeks now. He said he thinks it’s the fan clutch or secondary air pump but he’s not sure. I did have a P0441-00 code. Anyone have any ideas. Obviously he’s not to interested in diagnosing it.
Thanks,
Joe
Old Mar 3, 2021 | 12:50 PM
Blackngold77's Avatar
Worthwhile to give a tank on the e brake release cable to make sure they aren't rubbing.
It's next to the shifter and easy to get to.
Pull up the rubber piece on the passenger side then remove that plastic cover. From there youll find a steel cable loop. Just run something through that loop and give a couple hard pulls up.
Old Mar 3, 2021 | 01:55 PM
thanks for the idea. I should have mentioned I noticed the smell when I was warming it up in my driveway. I didn’t drive it at that point.
Thanks,
Joe
Old Mar 4, 2021 | 11:53 AM
AtlantaViking's Avatar
Get your nose close to the alternator (motor NOT running) and determine if the smell is coming from it. In my case, when my alternator started going south it smelled like electrical insulation burning. Might be your cause.
Old Mar 4, 2021 | 02:04 PM
That’s a good idea. I will pick it up from the shop and do some investigating.
Thanks,
Joe
seebeck1
May 31, 2020 10:09 PM
Robert Booth
Mar 21, 2017 03:08 PM
NickAdams
Aug 13, 2015 09:51 AM
bangkuaidiscovery04
Sep 25, 2009 11:08 AM
tsuami1
Jul 15, 2009 02:28 AM
