Help, HDC error after replacing steering rack/front rotors
Hi, I’m new to the LR family and already dealing with some e gremlins.
I changed the steering rack since it had a crack and I also changed front brake rotors and pads. Took my a while but went smoothly till I turn on the key and everything lighted up on the dash. I made the mistake to rotate the steering while the truck was up.(and a bunch of light appeared).
I bought a scan tool and was able to clear many faults but the ones on the pictures still there. I tried disconnecting the battery and touching the cables but that didn’t help either.
Before the repair everything was working smoothly but look like I messed with something during my DIY fix.
I did some things I read online but I’m still getting the HDC and supension lowered error after I change the brake switch sensor and both wheel speed sensor so those were not the problem. The steering wheel is at a bit off center 5-6 degrees, I actually reset it with the scan tool since was 720 when centered. I checked today and at full left is -570 and full right +570, so I think is ok.
any help on what can I check next since for a diagnostic they want to charge me $350 ( just diagnostic) I rather spend that money in new parts.
thanks
