Help me!
Help me!
So I got my 2005 lr3 hse 7 months ago and had to replace the driveshaft already :-/...
When I'm making turns now, left and right, I get a binding/grinding sound coming from the rear of the vehicle, it's getting more and more often, but dosent happen all the time.
Any ideas? My mechanic can't seem to pin point it! Thanks in advance
Put on a lift to get wheels off the ground put in drive( someone has to sit in the car on the lift) and listen to rears, , transfer case, hub bearings
How are the brake pads? Is the noise under braking while turning?
Is it stock, stock tire size?
While its up might as well check the a arm bushings with a prybar
alti
03-13-2013 08:30 AM
Speed racer
10-11-2008 10:56 PM
