Help me!
Old Nov 7, 2015 | 05:08 PM
Mechanicallydeclined's Avatar
Default Help me!
So I got my 2005 lr3 hse 7 months ago and had to replace the driveshaft already :-/...
When I'm making turns now, left and right, I get a binding/grinding sound coming from the rear of the vehicle, it's getting more and more often, but dosent happen all the time.
Any ideas? My mechanic can't seem to pin point it! Thanks in advance
Old Nov 7, 2015 | 05:18 PM
TOM R's Avatar
Put on a lift to get wheels off the ground put in drive( someone has to sit in the car on the lift) and listen to rears, , transfer case, hub bearings
How are the brake pads? Is the noise under braking while turning?
Is it stock, stock tire size?
While its up might as well check the a arm bushings with a prybar
Old Nov 7, 2015 | 05:23 PM
Brake pads are decent, and wheel size is factory as far as I know, all matching tires... The noise is usually under acceleration and when turning..
Old Nov 7, 2015 | 08:07 PM
TOM R's Avatar
Makes me think wheel bearing or cv but .......
Like I said run on lift it may reveal the noise unless someone has a better idea
Old Nov 9, 2015 | 09:25 AM
unseenone's Avatar
Sounds like the diff ie: left and right changes speed of the two wheels. Drain the fluid and see what it looks like.
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
