Help Please! 2006 LR3 HSE
Old Sep 20, 2012 | 06:53 PM
jokarover's Avatar
cool, I will try that!
Old Sep 25, 2012 | 12:06 PM
jokarover's Avatar
I did the test to close off the Main air intake and the truck started right up. and went to idle. I did not want to cause any damage so I shut her down. Should I have left it running and ran around to the engine to see if I could hear a hiss? I dealer told me it it is the upper intake manifold gaskets then it will be about 4 to 5 hours of labor plus parts. Is that right? I don't mind getting other people to work on my truck but when they try to clean me out for all I am worth then I have a problem.
Old Sep 25, 2012 | 01:21 PM
jokarover's Avatar
I think I will take the aftermarket MAF out and buy another one from LR. See if that does anything.
Old Sep 28, 2012 | 06:44 PM
jokarover's Avatar
Dealer had to do an ECM update and a new oil filler cap. I could not do the ECM update but I can do everything.
Old Sep 28, 2012 | 07:22 PM
ghengis86's Avatar
Doesn't sound right of you truly plugged the intake and it ran. Maybe you shut it down too soon? Anyhow, is everything fixed? All codes cleared? Oil filler cap replacement is strange, but whatev
Old Sep 28, 2012 | 08:18 PM
Rovin4life's Avatar
Without the oil cap it doesn't start at all its thats much air. Its possible the seal could be bad. hard to say. you can pull the upper intake yourself. You just need the proper tool to take off the fuel line. its a breeze after that. No real special tools.
Old Sep 30, 2012 | 11:07 AM
jokarover's Avatar
It is on the dealer now. That is the only thing good out of letting them do it. If they f up then they have an argument on there hands. So far no check engine light so I am guessing no leak. Ran me just over $400 after cutting all the fat from their quote.
KWickham
Aug 17, 2010 07:28 AM
Bean
Jul 15, 2010 11:13 AM
MagnaflowRep
Headers, Intake, & Exhaust
Sep 2, 2009 12:26 PM
LR3inCanada
Oct 27, 2006 04:24 PM
tprla
ROAMING WITH FRIENDS
Jun 7, 2005 09:19 PM
