Help w Lean code :/
Old Aug 29, 2019 | 09:46 AM
sickws6's Avatar
Originally Posted by abran
Did you spray brake cleaner around the engine looking for the leak? Do you have access to a smoke machine?
Will the break cleaner trick apply to leaking oil fill tube?
Old Aug 29, 2019 | 02:26 PM
abran's Avatar
Anywhere there is an air leak. That can be the fill tube, valve covers, intake tube...
Old Aug 29, 2019 | 10:19 PM
DakotaTravler's Avatar
Well, make sure the brake cleaner is flammable. Most now days are not.
Old Aug 31, 2019 | 09:43 PM
Identamerican's Avatar
Another classic and easy trick to find leaks is to mix a small amount of dish soap and water in a spray bottle. Spray on the tubes, if you see the tubes blowing bubbles you have a leak.
Old Sep 1, 2019 | 09:52 PM
Not for intake, its vacuum.
Old Oct 11, 2019 | 12:46 PM
sickws6's Avatar
any updates?
cybercop
Jul 17, 2019 05:42 PM
cybercop
Apr 4, 2019 02:56 PM
cybercop
Sep 2, 2017 08:30 AM
cipher982
Feb 27, 2013 08:59 AM
OldBob
May 17, 2011 05:10 PM
