Help! Water leaking into cabin
I found water under the driver floor mat, passenger floor mat, and passenger floor mat (behind the driver). This LR3 only has 1 sunroof so I taped it off with duct tape but a lot of water is still entering the cabin. I do not have a garage or carport. It is parked on a slope with the driver's side downhill. The water is now accumulating under the driver side floor mat.
Update: Found broken drain tube under driver side dash and plugged.
Probably....but I can just tell you, and others can chime in.
All of the sunroof drains - with the front passenger side being the most notorious.
The Pollen Filter Box - water gets past the windshield cowl and into the box and then into the cabin.
A-Pillar - on the passenger side under the A-Pillar trim piece there are holes that water gets through. Easy fix.
hazletbassist89
12-15-2008 02:17 PM
