Here's one....
Old Nov 15, 2021 | 02:18 PM
houm_wa's Avatar
Default Here's one....
I have sort of wrote this off as just a characteristic of the ZF transmission which - in both LR3s - works fine....but here goes.
I manual shift a lot. In my 2005 (130k miles) while shifting from 2 to 1, it will often "pop out" of 1 and go back into 2. If I shift while RPMs are a little higher (maybe 1500-2000) it tends to hold 1st more consistently. IIRC, this didn't start happening until after the software update to eliminate the CA stop effect.
In my 2006 (220k miles) it will often just not go from 2 to 1, and remains in 2. This is about a 50-50 deal, I'd say.
They have both had their transmission fluid "serviced." On the 2005 that means fluid was removed and replaced but the original pan and filter are still there. On the 2006, I'm not sure what was done because it wasn't mine at the time; but I have some service history.
Any thoughts? Are they just old? Is this normal?
Thanks in advance,
Houm
Old Nov 15, 2021 | 05:52 PM
loanrangie's Avatar
When it stops in 2nd does it then throw a fault or just revs out then changes up ?, i have a similar issue with 3rd and i can then ease off the throttle and it will shift down or it faults with the F on the dash and gets stuck in 3rd.
Valve body rebuild with new solenoids will be done in the new year.
Old Nov 15, 2021 | 05:56 PM
my 06 would do the not down shift pretty regularly pretty sure that trans was about to die though
Old Nov 15, 2021 | 10:30 PM
houm_wa's Avatar
@loanrangie No faults.... @ArmyRover You talking manual shifting only or even in Drive or Sport?
Old Nov 16, 2021 | 05:17 AM
Manual mode I use it off road a lot. It would do it in normal mode from time to time as well. Never sport mode though as I recall
Old Nov 16, 2021 | 09:45 AM
Blackngold77's Avatar
Wonder if it's a "protect the user from themselves" thing LR wrote into the computer. Basically don't let them downshift too early to avoid high RPMs and engine wear
Old Nov 16, 2021 | 11:45 AM
I don't think so as I was nearly stopped when I would try to shift
Old Nov 16, 2021 | 12:04 PM
houm_wa's Avatar
Yeah same....my REVs are definitely not that high when I downshift. On the '06 it's probably just wear, the thing has ~220k. On the '05 I still blame it on the B034 campaign. It never did that before the CA Stop fix.
bwLR06
Jun 7, 2021 03:40 PM
Spacedogb
Apr 16, 2021 09:31 PM
gfly66
Mar 22, 2017 10:13 PM
dodge_mich
Mar 2, 2008 07:30 PM
