how to add puddle lights
in addition to these there is supposed to be a light in each upper kick panel under the dash, they are the same lens and bulb as the puddle lights, drop the upper kick panels the hole is already cut just install the lens with bulb then locate the plug and plug in, stupid easy, can,t believe they were not just there from the factory
deepessions
Mar 24, 2007 10:32 AM
