how to add puddle lights
Old Nov 21, 2014 | 09:36 AM
TOM R's Avatar
Default how to add puddle lights
adding the puddle /entry lights easy but takes some time since you have to remove all 4 door panels
see the indent in bottom of panels
Size:  72.3 KB __________________
Old Nov 21, 2014 | 09:37 AM
TOM R's Avatar
inside there is a line molded to show where to cut
Size:  67.0 KB __________________
TOM R's Avatar
cut out with dremel, don't go nuts you can always make the hole bigger
Size:  64.7 KB __________________
Old Nov 21, 2014 | 09:38 AM
TOM R's Avatar
here is the light
Size:  69.3 KB __________________
TOM R's Avatar
plug is in that gray foam, also untape from harness
Size:  60.8 KB __________________
Old Nov 21, 2014 | 09:39 AM
TOM R's Avatar
installed and working actually put out a surprising amount of light at night
Size:  85.9 KB __________________
Old Nov 21, 2014 | 09:44 AM
TOM R's Avatar
in addition to these there is supposed to be a light in each upper kick panel under the dash, they are the same lens and bulb as the puddle lights, drop the upper kick panels the hole is already cut just install the lens with bulb then locate the plug and plug in, stupid easy, can,t believe they were not just there from the factory
bcbp
Aug 31, 2016 07:37 AM
LRScot
Sep 2, 2014 10:43 PM
Adam78
Mar 18, 2013 03:04 AM
bikeG976
Nov 14, 2009 03:53 PM
deepessions
Mar 24, 2007 10:32 AM
