How could this happen?
I live in the Northeast, NY to be specific. We got hit with a huge snow storm that hasnt even let up. Anyway yesterday i was driving my 2007 LR3 SE around in the snow, and it was doing great. It was handlin all sorts of snow covered terrain. Then i felt pretty confident and wanted to see how it would do going down a hill. Well it went down the hill, but now it wont come up. Its stuck. I dont get it. How could this vehicle get stuck in snow? The car is facing uphill, so its gotta climb up. Why did this happen in my LR3? Should i raise the suspension or lower it? do i put it in low range? what should i do?
RE: How could this happen?
I suppose you have tried the "snow" setting and the other settings? How are your tires? Good tread? Maybe you can let some of the air out of your tires so you have more surface area in the snow. Try backing down the hill a bit and then slowly accelerate up the hill. Good luck!
The easiest thing would be to go get some chains (one for each tire); well that's not true. The easiest thing would be to get some salt or driveway melter and a good shovel. You'll only need to raise the vehicle if you need the clearance. Use as high a gear as you can, too much torque will just spin the wheels. If the snow is deep it's kinda like sand, and you can let some air out of your tires (but then chains are out...). Honestly, brother, call a buddy, go get some chains. Keep them in the back (as you can only go SLOW with chains on) the weather isn't going to get any better...
Why did this happen? You're driving a 9000lb vehicle in the snow without snow tires (I'm guessing) or chains, and the vehicle lost traction. Not much different from the mud now, regain traction and get out. If the hill is kicking your butt, then walk the hill, plan your approach, dig out a track, salt and/or sand the track and kick the hill's ***; or, get ya some chains and then kick the hills ***. If that fails, call FT Drum and seek help from 10th Mountain If you're really stuck hard, send me a PM and tell me where you are, maybe I can come and help ya out I'm just couple states east and bored.
Good luck
Sam
Good luck
Sam
The number one mistake most Land Rover owners make is to think that because the hood sais "Land Rover" they can do everything. The best track and field runner would have serious issues if you put him on an ice scating ring and asked him to run with metal soled shoes. All the best traction control electronics in the world (and you have them in your LR3) will help very little if the tires you are using provide zero traction in the ice/snow. Do yourself a favor and buy a set of Good Year Silent Armours if you get that kind of nasty ice where you live. Then tell us how the LR3 handled the NY winter.
I think I can help you with your predicament.
I am sure when you realized you were stuck you were saying alot of 4 letter words but the only 4 letter word that would have helped you is JEEP
I also have a link for help with offroading in general......www.jeep.com
