How many miles are on your LR3
Old Jan 26, 2011 | 06:27 AM
twoxred's Avatar
Originally Posted by hell pie
I'm in the 76,000s on my 2005 LR3. Had a couple of major faults with one covered under warranty and another outside of warranty. I was able to handle a third fault recently by changing the suspension compressor. Last year I had to do some major cleanup and repairs after the floorboards were soaked due to the usual LR3 drainage syndrome. I also need to do something about the windshield cowl as I noticed my fresh air filter was damp after a recent car wash. I also need to inspect and tackle the front suspension soon as my front end has been clunking for some time. I also need to do a preemptive fix on my tailgate latch before it breaks. I also need to adjust my passenger rear door latch as it's been buggy lately. I also need to do the interior thermometer fix as I noticed cold air coming out of the top vents and hot air coming out of the lower vents simultaneously on a recent road trip. I also need to clean my battery as there is severe corrosion developing on the negative lead. I also need to flush my transmission fluid as I've noticed some hesitation in the morning. I also need to wax my car because it has never been waxed in the five years that I've owned it. I also need to get a life.
Rough, spend an hour in the D1 forum. It'll make you feel better.
Old Jan 30, 2011 | 05:56 PM
vinnysca's Avatar
6th Gear
33,800 miles on my 2008 LR3! EPB module replaced under warranty. Other than that, no problems! Knock on wood!
Vince
Old Jan 31, 2011 | 07:58 AM
safarisam's Avatar
91,000 on mine. Altenator replaced at 85k (drowned it in muddy water), rear upper inner front and rear A-arm bushings are worn out (anyone else?) just ordered replacement. Suspension light continues to be a nightmare, but its just a simple fix i have the parts for but am to busy fixing other cars to fix my own! (Failure to vent gallery, cured by a Rover TSB replacement of dryer and exhaust vent with additional holes). Spark Plugs soon! Changed the diff fluid and TC fluid recently as well. I use it like a truck, consistenly pulling trailers around. I do miss my disco II but the LR3 is just so much more solid and powerful. Regular offroad use when checking family and friends properties and fences.
What is the mileage others have reached before replacing plugs?
Old Feb 17, 2011 | 06:57 PM
n1keaddict's Avatar
Old Feb 25, 2011 | 04:34 AM
wallacej0505's Avatar
97,000 on my 05 LR3 and still love it.
Old Feb 25, 2011 | 07:43 AM
jasonre's Avatar
4wd High
I've got 58,000Km on my 05, no serious problems, just a few small ones I created, abusing it offroad.
Old Feb 27, 2011 | 09:08 PM
Southern Edge's Avatar
4wd High
Thumbs up
93,612 on my LR3/06. Had the"tire issues" in first 22,000, miles had to pay first (i was 2,000 miles or so away from my local dealer) but then my dealership worked out a new set for me later to get out of the factory tires. Other than that had to replace a broken hinge bolt on the back hatch. I have loved this truck and most of the miles come from family vacations and spring break road trips with my son. Makes a great base camp with the seats folded down and an air mattress in the back... Grand Canyon, Yellowstone, Glacier, Mt. Rushmore, Zion, Arches, Canyon Lands, Key West, Mt. Rainier, Everglades, Guadeloupe, Badlands, Carlsbad and Telluride. Good thing my work commute is only 3 miles.
Old Feb 28, 2011 | 03:02 PM
zim.dave's Avatar
4th Gear
321,000km on my 1997 tdi discovery, getting a bit long in the tooth but still a great ride !!
Old Mar 3, 2011 | 10:51 PM
amkullar's Avatar
Smile
Got an 06 lr3 4.0 v6 SE. 34k on it. I bought it in 08. Only problem i had was i had to get the computer chip that stores the software replaced. But i was under factory warranty. Other than that no problems.
Old Mar 11, 2011 | 01:32 PM
mrb06lr3hse's Avatar
2006 LR3 HSE now with 74k
I've had it since 10/2010 and 63k
New tires
New Front & Back pads & rotors
Air leak problem - led to air intake tube, EGR Valve and Oil Fill Tube replaced
Suspension Faults - replaced compressor and wire harness to suspension control valve that wouldn't carry a load
Hood Strut - obviously minor
Sunroof problem - won't open now after 1 forgetful night (left sunroof open and it rained) :-(
