How many miles are on your LR3
Old Jan 6, 2012 | 10:58 PM
  #51
Stark_zx10's Avatar
Recently purchased a 2007 LR3 HSE with 70k miles on it.
Old Jan 8, 2012 | 10:57 PM
  #52
Sonies's Avatar
8th Gear
I recently bought an 07 with 55k on it
Old Jan 9, 2012 | 10:40 AM
  #53
unseenone's Avatar
Purchased new in '05 now 100k miles.
Old Jan 9, 2012 | 11:24 AM
  #54
PJH's Avatar
PJH
5th Gear
Default 2007 56K LR3 Miles
Solid for the first 50K miles, since then a few issues; Parking sensors stopped working, wipers not working properly, cooler not working.
Old Jun 4, 2012 | 08:50 PM
  #55
ICECREAMEATER's Avatar
170k and traded it towards a LR4
Old Jun 5, 2012 | 11:18 PM
  #56
pilotgabe's Avatar
2006 V8 SE 83,300, just bought a few months ago with 75,500. Great truck!
Remote isn't working (was intermittent)
Replaced rear brake rotors last night
Cleaned TB and MAF due to "Engine Reduced Performance" message; so far so good
Needs right rear emer. parking brake shoes; no material left at all
- (EPB started making screeches when enabled, so I disabled it while I troubleshot)
Changed all 4 tires
Needs terrain response panel in center console; off-road height selection not working
Needs lower control arm bushings (or just control arms)
Needs control arm end links
Otherwise, love the LR3!
Old Jun 6, 2012 | 09:34 AM
  #57
mirepoixmatt's Avatar
2006, 81K, a compressor, few sets of brakes, a suspension fault or two (height sensors), and a good amount of unnecessary stress dwelling on the cost of things I ultimately don't need!
Old Jun 6, 2012 | 10:27 AM
  #58
unseenone's Avatar
It would be good to note, you should change your transfer case oil at 75k, transmission fluid at 75k, and differential oil every 25k.
104k
Rebuilt rear then front differential. Filled to spec with Royal Purple
75k Fitted metal pan and Lifeguard 6 oil changed in transmission
Fitted Koni dampers in air struts, new seal kits.
Replaced front CV joints, wheel bearings, upper and lower suspension arms.
Replaced rear suspension arm bushings, wheel bearings.
Replaced all belts, pulleys, tension arms.
Replaced front and rear roll bar bushes.
95k Replaced brake light switch and brake light bulbs.
95k Repaired stuck shut tailgate.
20k, 104k Refitted new EBC slotted rotors and brakes, first set lasted 80k probably had another 10k in them.
Car handles better than new!
Old Jun 6, 2012 | 04:53 PM
  #59
Actus's Avatar
6th Gear
57,987 - O2 sensor just went and the inner tie rods were loose but had that problem resolved.... I think I dropped a wrench and it stuck on the under armor somewhere...
Old Jun 10, 2012 | 06:40 AM
  #60
threalassmikeg's Avatar
Almost 95,000 on mine..
What is this metal transmission pan you speak of unseenone?
