how to remove fender vent
BTW, for those who may be interested, this is the best way I've found to remove the vent without breaking anything. Stand with your back to the vent, facing away from the car. Put your fingers/hands under the middle horizontal bar on the vent and lift up. As you lift up, rotate the bottom of the vent out. When you face the vent, it is infinitely harder to get the right leverage and angle.
Good tips for removing vent designed to be easily installed during mfg of vehicle. Obviously will break tabs when removed 80% of the attempts. Also designed to help boost spares revenue? Plastic parts suck but do recall the metal spring tabs or other fasteners failing/rusting as well.
wheelgarage
Oct 1, 2011 03:12 PM
JavaDiscoII
May 16, 2010 03:34 PM
