how to remove fender vent
Old Dec 9, 2014 | 06:57 PM
TOM R's Avatar
Default how to remove fender vent
pics provided by DanC thanks Dan
Old Dec 9, 2014 | 06:59 PM
TOM R's Avatar
Old Dec 9, 2014 | 07:00 PM
TOM R's Avatar
Old Aug 2, 2017 | 05:51 PM
TOM R's Avatar
When you have the vent off pull out that rubber boot, if there is a big piece of foam behind it remove and throw away, it blocks a drain, reinstal boot
Old Aug 4, 2017 | 01:12 PM
cmb6s's Avatar
BTW, for those who may be interested, this is the best way I've found to remove the vent without breaking anything. Stand with your back to the vent, facing away from the car. Put your fingers/hands under the middle horizontal bar on the vent and lift up. As you lift up, rotate the bottom of the vent out. When you face the vent, it is infinitely harder to get the right leverage and angle.
Old Aug 4, 2017 | 01:37 PM
DavC's Avatar
Yeah when I made these pics I did exactly that after reading one of your posts. I think its just luck of the draw.
Old Aug 6, 2017 | 12:10 AM
number9's Avatar
Good tips for removing vent designed to be easily installed during mfg of vehicle. Obviously will break tabs when removed 80% of the attempts. Also designed to help boost spares revenue? Plastic parts suck but do recall the metal spring tabs or other fasteners failing/rusting as well.
Old Aug 6, 2017 | 09:13 AM
Andy_R's Avatar
First post here!
Good tips on how to remove and about the foam. I figured you faced away from it because watching yourself take this off the first time is too hard to watch.
wheelgarage
Oct 1, 2011 03:12 PM
JavaDiscoII
May 16, 2010 03:34 PM
caleb
Jan 6, 2010 11:26 AM
elrocha69
May 18, 2008 11:52 AM
Ray
Nov 11, 2005 11:42 PM
