Idle problem, not MAF, T/B, or Air Filter
Old 07-29-2015, 11:50 AM
kid A's Avatar
Default Idle problem, not MAF, T/B, or Air Filter
2006 SE, V6, 80k miles. Here's what happens: I'll be driving around fine, and then when I sit in park with the engine running, about 3 minutes in the rpm's will dip from 750 to liike 700 and the truck will begin to shake. After this goes on for a couple minutes, the front end lowers, no idea why. It never quits, it just shakes on and off. Threw a CEL, so I gotta get that read. I'll post when I do.
Just cleaned the MAF, throttle body, and changed the air filter. What else could this be?
Old 07-29-2015, 04:15 PM
houm_wa's Avatar
Thermostat??
Old 07-29-2015, 08:01 PM
kid A's Avatar
Codes are:
P0406
P0108
Old 07-30-2015, 07:03 AM
acamato's Avatar
Once of the codes is related to the EGR valve. Did you try cleaning the EGR valve?
P0108-Manifold Absolute Pressure/Barometric Pressure Circuit High Input.
P0406-Exhaust Gas Recirculation Sensor "A" Circuit High
Old 07-30-2015, 07:07 AM
kid A's Avatar
I haven't done the EGR yet only because it looks like a pain to get to. I think I'm going to try some easier things first (that probably need to be replaced anyway) like the MAP and the PCV valve (even though I have no idea where it's located after looking at diagrams for an hour, see my post in tech section).
Old 07-30-2015, 11:16 AM
kid A's Avatar
After more research, the EGR isn't hard to get to, it's actually right in front of my face.
Looks like this thing needs a total replacement, no?
Old 07-31-2015, 06:53 AM
acamato's Avatar
Rather than spending $$ on a new valve. I would try unbolting it from the manifold & exhaust pipe and use carb cleaner to clean the valve from all the carbon buildup.
There's a pdf in this thread on removal: https://landroverforums.com/forum/lr...ve-leak-53557/
Old 08-02-2015, 10:38 PM
houm_wa's Avatar
Isn't the valve pretty darn cheap?
Old 08-02-2015, 10:42 PM
kid A's Avatar
Aftermarket is like $250. OEM is more like $300.
I may just replace with whole thing with aftermarket anyway.
Old 08-03-2015, 05:15 AM
june82000's Avatar
i'll bet you have a vacuum leak somewhere. Start off by looking over all your vacuum line connections, giving them a gentle tug to make sure they're still tight. A common one is the PVC elbow on many cars. While it's acting up, you could spray a little starting fluid around the connections to see if your idle momentarily increases. That's a dead giveaway. you can buy me a beer if I'm right 😎
Quick Reply: Idle problem, not MAF, T/B, or Air Filter
