Ignition Coil Pack Bolt Broke
Hey all, went to swap the ignition coils on my ‘08 LR3 and the bolt broke in half as I was trying to remove it. Does anyone know if you can use an “easy out” tool or something similar to get a bolt that is broken in half out of where you screw it in to install ignition coil packs? Also, does anyone know of the part number that goes to that screw? Is it something you can pick up at the hardware store? Here’s a photo of an example of what I’m talking about.
Thanks!
Thanks!
I would just drill out with slightly undersized bit smack down the center. Once through the thin remnant of the bolt will spin out.
If you end up messing up the threaded brass insert, you can always pull out and epoxy another in its place. Worst case scenario you change out the entire valve cover.
