Immobilizer permanent bypass
Old Dec 30, 2022 | 11:40 PM
rikkd's Avatar
Default Immobilizer permanent bypass
Is there a way to permanently bypass the immobilizer? I take my rig out a lot and looking to find a way to foolproof my system as I lost the key I had in Hollister and have to return to retrieve the car after the key disappeared (as stupid as it sounds we had 4 people looking for it and no one found it) I was looking to make or be able to create a key out of anything incase this does happen and or use a spare dumb key. I plan to make an all metal key to hide inside the vehicle. I know I sound crazy disabling a security system but this car is too smart for my liking, stupid as it sounds I want to be able to craft anything to work with the vehicle in case of emergency. I'm unfortunately not interested in the safety features as I am fine with the risk of theft but with key redundancy.
Old Dec 31, 2022 | 11:19 AM
Coldwater's Avatar
Do you have the gap tool? You should just make a spare key and hide the key somewhere safe and secure on the exterior. Probably a lot easier than trying to convince the Rovers computer
Old Jan 2, 2023 | 03:55 PM
rikkd's Avatar
I don't . I was looking at it as there's another lr3 in the family and I would like to have more control over air suspension (already tired of swapping out lift roads at the trails) and with a roof top tent its a little top heavy on the highway. I did come up with a possible solution. The car will still lock if there is a key inside, so I was going to take apart one of the good keys and take the RFID chip and put it under the steering wheel so the car can see it (assuming it doesn't need a metal connection to the ignition). and allow me to store the dummy key somewhere. I was thinking of the exterior but I don't want the risk of it falling out on the trail or if the airbags fully deflate and I'm unable to get under the car. I cant find a good spot on the sides or top of the car that is secure or discrete enough. This with having a string/laynard attached to an offroading only key and tying it to an air vent to prevent this from happening again.
Murphdizzle
Jan 19, 2023 09:58 PM
cappedup
Jun 9, 2015 06:04 PM
shltn
Oct 2, 2013 11:11 AM
Jeff4190
LR4
Jan 28, 2011 12:00 AM
iplayblues4u
Jun 30, 2010 06:02 PM
