Inner tie rod??
Old Jul 5, 2012 | 04:51 PM
bmwrovers's Avatar
Default Inner tie rod??
just got word from the shop that my 05 LR3 with 30k needs a right inner tie rod end (has some play)... after looking at the part on atlanticbritish, it does look a bit "foreign". i've done tie rods before on my D1 and such... but is this something i should/could tackle on the d3?? anyone have a DIY thread out there in rover world?
i've read that some don't think this is the issue at 30k, and i don't have any clunking sound or noise from the front end... just a little steering wheel shake. i just put new tires on to pass inspection and the previous ones (from previous owner) were pretty worn on the edge.
i'd rather not pay my local shop $600 to do the job that a $30 part would take!
do you think maybe just an alignment would be the right remedy?
Old Jul 5, 2012 | 04:56 PM
ktm_525's Avatar
LR3s seem to eat tie rods. This is a straightforward DYI, nothing special here. You will want to do the outers as well (balljoint end). Simiply remove old balljoint, remove outer tie rod, vice grip the inner out (they thread in but the ones I removed had no wrench point). Install the new parts.
Old Jul 14, 2012 | 01:44 PM
Rovin4life's Avatar
oh and have it aligned or else the suspension light stays on cause of the alignment is off.
Old Jul 15, 2012 | 10:37 PM
ktm_525's Avatar
Yes excellent point. Front end needs alignment after monkeying around with tie rods.
holiveira
Feb 28, 2015 10:21 AM
dfauver1
Apr 9, 2014 05:49 PM
killerpav
May 7, 2012 12:23 AM
cbwhitley
May 29, 2007 06:44 PM
jcw
Oct 27, 2006 08:26 PM
