Installing CJB
Hello, I’m got the treaded 3 amigos faults , HDC Transmission and suspension. I replaced the tcm , replaced the battery and brake light switch. Want to check the connections and the pins of the CJB. This looks like a nightmare to disconnect and connect back. Any tips or suggestions how to out this back? TIA. I have a 2006 LR3 V8.
Thanks for your response. Yes I have the gap tool. Here are the faults:Instrument Pack
- U0132-87 (26) Lost communication with ride level control module - Bus signal/message failure - missing a message
- Test Failed This Monitoring Cycle
- Pending
- Test Failed Since Last Clear - U0184-87 (2F) Lost communication with audio unit - Bus signal/message failure - missing a message
- Test Failed
- Confirmed
- U0416-86 (24) Invalid data received from vehicle dynamics control module - Bus signal/message failure - signal is invalid
( on 18-01-2024 19:56:58 at 76539 mi )
- Pending
- U0416-94 (24) Invalid data received from vehicle dynamics control module - Component failure - unexpected operation
( on 18-01-2024 19:56:51 at 76539 mi )
- Pending
- U0416-86 (2C) Invalid data received from vehicle dynamics control module - Bus signal/message failure - signal is invalid
( on 18-01-2024 19:56:53 at 76539 mi )
- Confirmed
- B1B78-84 (2F) System pressure - Bus signal/message failure - signal is below allowable range
( on 18-01-2024 19:55:36 at 76539 mi )
- Test Failed
- Confirmed
A bad cluster is possible. Clusterfix.net repairs them and keeps your odometer. It’s not cheap, but if you check their website, you’ll see similar symptoms. My 07 needed repair. I have not had to do my 06.
...and how about damp floorboards? There are a lot of wiring looms that run under those areas; water sitting under the carpet for prolonged periods of time can lead to corrosion and/or severed wire connections.
"Most of them [ECU's] are VIN locked and cannot be swapped from one vehicle to another. The transmission is an exception. It can be done via fast lane."
But, first, you might switch back to your old TCM. Look for corrosion inside the old TCM and clean connectors and give it a try. Check out Rene Clausen's video here:
To remove the CJB, follow this video:
I would also diagnose the ODBII port to check for proper voltage, grounds, and especially your CAN Bus, which for me caused "lost communications" errors. You'll need an inexpensive multimeter.
