instrument cluster issues
Old Nov 29, 2016 | 12:09 PM
mhart08's Avatar
6th Gear
Default instrument cluster issues
Hey all,
New member to the community as well as a first time owner of a land rover.
I am having an issue with my '05 LR3 SE instrument cluster. Randomly It will loose all power. Some times during start up, some times while driving. So far after 30 seconds it kicks back on.
Sorry if something similar has already been posted i was unable to find anything threads that could help.
Old Nov 29, 2016 | 09:49 PM
bbyer's Avatar
Default big plug in rear loose
My guess is that the single big electrical connector that plugs into the rear of the instrument cluster assembly is loose.
It seems the primary cable is a bit short and hence there is always a pull out tug on the connector.
Normally, it shows more as a temperature or fuel gauge that will not indicate, or worse yet, a sort of shutdown or non start of the engine.
Within the insrument cluster pcb is the backup memory chip for the car computer. The primary chip is located on a pcb on the rear of the glove box fuse panel. The main and backup chips are supposed to be always in communication with each other and when not, then bad things happen.
DISCO3.CO.UK - View topic - Instrument Cluster Speaker
At the bottom of page re the link below is a jpg of the rear of the instrument cluster. The rectangle in the top left is where the plug plugs in.
You should not have to totally remove the cluster; if you can access the plug just try resetting it. I presume it is just loose so pushing on it should reset it.
http://www.disco3.co.uk/gallery/albu...D3_Speaker.pdf
Smhube00
Mar 11, 2025 07:51 PM
mhart08
Nov 29, 2016 12:00 PM
riko suave
Mar 18, 2009 04:34 PM
coldfrez
Oct 1, 2007 09:49 AM
Greg
Aug 8, 2007 04:47 AM
