Interior Issue
Old Sep 6, 2016 | 10:16 PM
Fryvet's Avatar
3rd Gear
Default Interior Issue
Hello,
I have an '07 LR3 that has the fabric carpeting of both interior "A" pillar failing off. Anyone have any good remedies, or should the be replaced if even possible?
Thank you for any help that can be provided.
Old Sep 6, 2016 | 11:11 PM
delormea397's Avatar
I have had small interior panels reupholstered very cheaply at a local auto upholstery shop. When I was younger I have also tried myself.... one recommendation though. If you do, don't bother with any of that rattle can upholstery glue. It doesn't hold a candle to the real stuff that you load in a HVLP gun and an air compressor. But if you aren't already set up with a cheap HVLP gun that you dont mind getting ruined by glue, it's likely cheaper to have a shop do it. I figure I could get both done for $100-150 here. Your mileage may vary.
Old Sep 7, 2016 | 01:37 AM
clarkritchie's Avatar
Mine is doing the same. I was told that is a common issue and I plan to have a local upholstery shop tidy it up it since I am terrified I will inadvertently inflate one or both of the air bags!
Old Sep 7, 2016 | 05:47 AM
DavC's Avatar
hot glue gun works ok, just use the higher temp glue.
Old Sep 8, 2016 | 01:02 PM
babyxbuffalo's Avatar
I have the same thing happening to mine. Need to find a good shop here in southern california.
Old Sep 8, 2016 | 07:41 PM
abran's Avatar
I got one. They do complete D2 headliner for $250.
Call Joel, Tell him Abran sent you. They are in Anaheim
714.702.3254
Old Sep 8, 2016 | 08:03 PM
SoCal Rob's Avatar
I took the plastic trim piece off (1 Torx screw, I think), carefully applied some spray adhesive (Pep Boys - Permatex All Purpose Spray Adhesive in my case) to the plastic, and then gently pressed the original fabric back onto the plastic trim piece. No more flapping A-pillar fabric.
-Rob
RWAC94
LR2
May 3, 2015 12:29 AM
usnavylt
LR4
May 1, 2015 03:40 AM
jdwilks
Aug 27, 2014 10:59 AM
wabuson
Oct 5, 2012 04:16 PM
dms98e
May 9, 2008 08:36 AM
