Intermittent Overheating
Old Nov 2, 2019 | 04:09 AM
Skullbiker's Avatar
I just experienced the same thing - eager to see the replies here ��
Old Jan 5, 2020 | 11:04 AM
prossett's Avatar
Update on this: issue solved. It was the water pump that was failing. Replaced that, but then didn't burp the engine properly and the expansion tank was boiling over like it was a certain blown gasket. Really scared the bajeejas out of me! I've never seen an air bubble affect the cooling system so badly before (and I'm 52, with plenty of wrenching).
Anyways, after a while to ponder, and reflect that I'd better start over rather than begin head gasket calculations, and then the system settled perfectly, and to this day is running fine, with its new water pump.
A note that the PO had removed the bleeding T-connector at the top of the engine, and replaced it with a short copper straight-pipe. Not a good idea. Replace with a better-designed bleeder, if necessary, but not a straight cut.
Old Jan 5, 2020 | 11:09 AM
DakotaTravler's Avatar
Thanks for the update, always nice to post such things to help others resolve their issues.
znerhunter
Nov 9, 2017 09:38 PM
vonrock
Feb 13, 2014 12:34 PM
DiscoRover007
Mar 9, 2012 10:01 AM
Disco2Fever
Aug 1, 2011 04:00 PM
rightsandlefts
Mar 17, 2010 07:49 AM
