#5 Fuel Injector
Old Jan 4, 2020 | 09:09 PM
HayesLR's Avatar
Default #5 Fuel Injector
I have a 2005 LR3 and dialed up P0205 code two months ago. I replaced the coils, plugs and didn't resolve the issue. I tested the the injector and it was bad so I replaced the injector and ran better than ever! Today I had a misfire in #5 with the same code so tested the injector and it was bad. I replaced the #5 injector again and my LR3 ran perfect. Is there something that is causing #5 fuel injector to go bad or just bad luck?
Thanks for any help.
GH
Old Jan 5, 2020 | 12:54 AM
Globetrotter448's Avatar
when you say "went bad" what do you mean - clogged, not working etc. It may be an electrical problem on that injector circuit or you need to use a fuel system cleaner in your fuel, not the additive. Could be a problem with that cylinder like plug, lead, coil etc.
Old Jan 5, 2020 | 08:13 PM
HayesLR's Avatar
Thanks for the help. I tested the fuel injector with a meter and it was dead. Drove it today and ran great. I replaced the coil, plug, and then finally the injector two months ago. I am trying to figure out if its just bad luck and the #5 injector went bad twice in two months or if there is something else causing the injector to go bad. Thanks again for the response and help.
disconic
Aug 26, 2019 08:05 AM
bjordan
May 27, 2019 04:58 AM
GWDRoverTX
Sep 13, 2016 09:24 AM
roverspecialist
Mar 22, 2010 06:42 AM
tornado_735
Mar 30, 2009 08:21 AM
