Just got an LR3, looking for some AUX input help
Looking for someone that has the AUX input on the back of the center console that has the time to take a picture for me. What I am looking for is a picture of the green 4 wire connector that goes into AUX input once you pop it out of the console. It is very easy to remove all you need is a flat head screw driver and you can pop it out. What I'm trying to diag is why I only have right side sound when I use the AUX input. I found a Land Rover wire diagram of the connector and the way the wires are arranged in the diagram do not match my connector so I was hoping someone could take a picture of the their working connector so I can verify if someone had been in the connector and put the wires back in it wrong or if I just have a bad aux input. If someone has the time to do this for me I would really appreciate it.
I had bad sound when using an iPod thru that AUX with a straight headphone jack type cord
My sounds was from rears only - not front, even though all other inputs (radio, cd) sounded fine from all speakers
I bought an old-school Griffin adapter (powered, boosted) for $6 LOL
Now my sound from the AUX via the iPod (thru the adapter) is as good as I would have expected!
https://www.amazon.com/dp/B003SX0O34...iglink21385-20
My fix was I scored a replacement part from a recycler for $30 when I was getting some other parts. When I have more time I will look into a repair using a regular 3 wire aux input cord tapped into the 4 wire connector. Since the body side connector is only 4 wires I feel that this could be easily tapped into and a different input cord/port could be mounted in a more convenient location
