Key fob only works once between engine starts
Old Oct 6, 2024 | 12:08 PM
Aga's Avatar
Aga
Default Key fob only works once between engine starts
I tested the key fob it's sending the signal at correct frequency with each press of any of the buttons.
The issue is that when I switch off the engine and take the key out I press a button and it will work, but if I press again and again and keep pressing nothing is happening with the car like the signal is not received. When I put the key back in the socked and start the engine then switch is off take out the key it will work again but ONCE only, so only 1 press of a button. Anyone else had similar problem?
Old Oct 6, 2024 | 05:45 PM
DakotaTravler's Avatar
Battery in fob needs replacement.
Old Oct 7, 2024 | 02:10 AM
Aga's Avatar
Aga
Thank you but I bought a frequency tester and the key keeps sending the signal each time I press a button
Old Oct 7, 2024 | 07:39 AM
x81's Avatar
x81
7th Gear
Have you checked the splice for the antenna ground? Passenger side, front door, in that large loom under the sill trim. If you've ever had the sunroof drains blocked/degraded/torn, it can corrode and cause the issue you're talking about.
Letran
LR2
Oct 18, 2024 06:30 AM
Trauma
Aug 16, 2022 10:59 AM
Yosoymilk
May 24, 2022 12:00 PM
jrf07d
Jan 14, 2022 03:19 PM
tucsonny72
Sep 5, 2011 05:09 PM
