Land Rover LR3 Fault Front Right Air Blend Actuator – Location And Access
Old Nov 13, 2019 | 07:01 PM
PedalToTheMetal's Avatar
6th Gear
Default Land Rover LR3 Fault Front Right Air Blend Actuator – Location And Access
My LR3 shows the fault “Front Right Air Blend Stepper Actuator”, the passenger side is also only blowing cold air.
I tried to recalibrate the climate control, however without success.
If I read the drawing in the service manual correctly, the air blend stepper motor for the passenger side is is located behind the dash center panel on the driver side.
Is this correct? Is there an easy way to access it? Frankly, I can't quite figure out how to get there, without ripping half the interior apart.
Reading through the various threads regarding the air blend motors, it appears as whether I am the only one who struggles to get there.
Oliver
Old Nov 14, 2019 | 09:45 AM
jagmandan's Avatar
Check the workshop manual for the steps. You have to remove a lot of the center console and lower dash. It is a frustratingly large amount of work for something that seems so close, but as far as I know there is no other way that's not a hack to get there.
Old Nov 14, 2019 | 10:59 PM
6th Gear
Thank you for your response. I was afraid, that there will be no easy way to get to it.
Oliver
ljdiscovery
Mar 5, 2019 06:28 PM
Charlie_V
Jul 1, 2016 10:27 PM
Disco3JR
May 13, 2016 06:56 PM
slexum
Dec 27, 2008 07:03 PM
RANGER46
Nov 29, 2008 02:09 PM
